Best price for lowering springs installation?? :(
so far ive asked a lot fo places for quotes on just installing my eibach pro-kit springs on my x. the price range that i got was $275+ and that doesn't even include the alignment which you have to figure almost $100 in itself, how could the installation cost a lot more than the part lol i mean i know labor and all that bull, but damn. anyone know of a good place around north jersey that would do this for a reasonable price? i would do it myself but i have no knowledge whatsoever about replacing suspension, along with the fact that i don't have a spring compressor. also, if any fellow evo owners around this area could help me out with this installation il get lunch and a six pack
if you just live in socal, i can hook you up for a $100,.
$275 is just way too overpriced, after watching the installation, i figured i can do it myself the next time. no need to take out the rear seat.
Registered User
$275 does not sound way off. Fronts are super easy but the rears have a lot of stuff to remove (and put back) to get to the nuts. If you figure that a professional shop would do the work in their facilities, with their trained mechanic and their tools at about 3 hours of labor at $80 per hour it's easily $240. Add tax etc and the $275 sounds reasonable. It would have to be a real good friend that would do it for lunch and six pack
KevinD from Evolution Dynamics here in Dallas can do it for 100.00 bucks. Obviously your not in Dallas, but it may give you some bargaining power.
http://www.evodynamics.com/
i dont know with you brodah, but for me spring install for that amount is ripping someones pocket off. i had mine installed for $100 in a shop too and only one person did it for less than 2 hrs.
1 Post
If you were closer I'd say bring it on over and I wouldnt even charge you a 6 pack... I'd supply the beer. If you want to take it on yourself, there are 2 tools that a must needed. Spring compressors (AutoZone 27036 $50 to rent, and an impact gun, either electric or air). Everything else is just time.
Ha, I've only checked with one local performance shop to see how much they want to install my Swift Springs and they quoted me $315 (without alignment). That is in Denver tho
You do not need a impact gun to the springs. I did it with just a a breaker bar, torque wrench, and spring compressor. For the rears hold the little silver nut/disk before the nut with a set of large vice grips and then get a breaker bar to loosen up the nut. The rest is easy.
$275 is not bad. There's an Evo shop near me that charges $85/tire.
I did mine alone (I have a IX though). Rented the spring compressor from Autozone for $53. They refunded the money as soon as I returned the compressor. Had alignment done at Euro-Tire for $144.45 including tax.
Registered User
as ive said, you dont need to remove the rear seats in order for you to get to the nuts. just remove the plastic panel inside the trunk and you can see it on each side.
