Rotors for the X
Rotors for the X
OK, I'm trying to track down what's available.
2 Piece:
Girodisc
DBA 5000 series
1 Piece:
Girodisc
DBA 4000 series
Centric (Tirerack)
IPX Sport
IPX Premium
EBC
Does anyone have any thoughts on the DBA vs. the Girodisc in the 2 piece? There's a pretty big price jump there... especially comparing X vs. VIII/IX.
And where are the other vendors on 2 piece rotors?
2 Piece:
Girodisc
DBA 5000 series
1 Piece:
Girodisc
DBA 4000 series
Centric (Tirerack)
IPX Sport
IPX Premium
EBC
I plan on getting the Girodisc front 2 piece rotors, I already got the rear 1 piece in place.
Finally found some info on the DBA 5000 rotors:
http://www.livermoreperformance.com/dba_rotors.html
You weren't kidding on the price jump of the DBA 5000 series rotors from Evo 8/9 to Evo X, I'm betting lack of competition.
They shouldn't be less expensive for the initial cost than single piece but should cost less to replace as you are only replacing the rotor "ring". The biggest changes with my set for the IX was the ability to shed heat way faster and they are lighter. I am now looking into changing the X rotors..and wondering how the aftermarket rotors will compare to the stock 2 piece on the X-MR ? I did see the Giro prices posted on their site..but I am looking for input from users of the 2 piece setup(s). Thanks, Pete
My understanding on the difference between the stock MR two piece rotors and the Girodisc 2 piece rotors are:
- the iron used in the stock rotors is junk and the girodisc rotors are ductile iron and will take more heat and dissipate it better
- the internal vaning on the girodisc rotors (all of them) helps to pull air through the rotor, cooling it as it turns.
There are potentially differences in the way that the floating pieces attach and allow for movement of the hat relative to the rotors.
The internal vaning on the DBA rotors is their "kangaroo" vaning, which uses a bunch of different shapes to help cool the rotors.
Girodisc Martin
32
Mar 29, 2011 12:17 PM
Hiboost
13
Oct 6, 2009 11:06 AM
