Alignment question
Alignment question
I've been reading old threads about this and want to just ask a simple question:
When going in to get an alignment at a shop, is the only thing they are able to change the toe?
I've been reading that the caster/camber are not adjustable (other than the flipping of the nut method for camber). I just want to be sure because I've lowered my car and went in to several shops who either say the car is too low to get an alignment or the only thing they can adjust is the toe. I was looking at getting the Firestone alignment for life deal, but had second thoughts after they told me they could only adjust the toe.
So in the front, the toe is adjustable and nothing else.
In the rear, the toe AND camber are adjustable.
This clears it up, thank you!
When I went in to Firestone, all that came up in their system was that they could adjust the toe. They didn't have any data on what the camber/caster settings were for stock front or rear. I guess I'll just have to take a printout of what the stock specs are and see how close they can get them for the rear.
You can get a "free" -1*+ of camber in the front by removing the wheel, removing the top strut bolt, and flipping it such that the white dot of paint on it points away from the strut (this is the same on the 8 and 9). You will need an alignment after you do this since it will make the toe change.
https://www.evolutionm.net/forums/ev...fications.html
^ that sticky is really helpful.
Got my Eibach Prokit from Evasive Motorsports. They installed the spings and aligned it as well.
-2 all around, no camber plates.
Firestone
edit:
there's actually a pdf document floating around here with a diagram on camber settings.
^ darn
If Firestone cant even adjust the camber settings, I dont see the point of going. You might as well adjust it yourself.
Page two of the sticky thread, someone has a DIY instructions. goodluck, sir.
question is, would it better to adjust the camber settings yourself before going to Firestone? [Firestone for toe settings only] or is it the other way around?!
Well, I think since the data in their systems only had toe settings, they assumed they couldn't change front or rear camber, when in reality from what I've been reading, they can change the camber on the rear. So all they would be adjusting is the front and rear toe, and the rear camber. Nothing else.
After lowering, it visably looks like I have negative camber, so I don't think I'll be adding more to the front by flipping that nut unless I find that my new wheels rub (which they shouldn't).
And adjusting the camber affects the toe, so I would assume they would adjust the camber in the rear before adjusting the toe.
This is correct.
And if you just got lowered, go get aligned or you'll be buying new tires too.
The process is:
Rear, adjust camber
Rear, adjust toe
Front, adjust toe
When they get under the car in the rear, they'll see both the camber and toe adjustment eccentrics. If they don't then they're blind.
