How is the rear camber adjusted?
There are two eccentric bolts/washers in the rear on each side. One changes toe, one changes camber.
You need two 17mm wrenches. You loosen the nut on one side of the $20 bolt and then turn the bolt head to roll the $10 washer in a slot cut into the suspension arm. Once it's set, then you tighten the nut back down. These bolts/washers last approximately 6-7 alignments before one or the other strips out. In my case it's been the washer. This is especially true if you are aggressively dropped and you're putting a lot of pressure on these pieces to get a good alignment.
Of course if you take it to a place and they can't figure this out by looking at the rear suspension for about 2 seconds, then you need to take the car somewhere else.
dipsetinallday
11
Apr 28, 2016 06:02 AM
mitsuevodriver
19
Jan 17, 2016 08:37 AM
