Stock Enkei
Stock Enkei
I'm having some major paint issues with my stock Enkei's, paint is bubbling up near the center cap, spokes and even on the backs of the rims!!! This isn't Mitsubishi fault, where do I go to resolve these issues, they can't lean on the anti perforation as these are aluminum wheels and we all know their not suppose to rust lol, do I contact Mitsubishi or Enkei??? Any ideas would be great!
I took my Winter tires/stock rims off in the spring and they looked a little rough, paint was bubbling and so forth (very minimal). I cleaned them up and covered them with a blanket... I live in Ohio and the weathers starting to get colder and I can feel the snow flakes coming on, so I pulled them out and they look terrible! I do have curb rash on two of them, one very, very small and the other noticeable, but the paint is effected on all 4 wheels, center caps and spokes namely, however it's even spread so far as the outer lip on the back side. I'm sure their going to try and fight me tooth and nail over this... If any of you guys are experiencing this, please by all means post pictures and info as I can use to our advantage, in hopes they will be warranted!
go back..
if they are stock enkei rims.. i would hit up mitsu fasr and see if they are still under warranty. If so you should get them replaced for free.. if not.. look at spending about 825.00 a wheel not to include the tires.
Bubbling is usually caused from the wrong prep for them being painted. If the wheels were painted at the factory and had some type of oils/ greases on it, it will cause it eventually to bubble because it does not have something that it can bond too.
you could always re-paint them ..
i know this is a little off topic but does anyone know if enkei has center cap that fit the stock gsr rims with there logo on them insted of the mitsu diamonds ? thanks and good luck with paint issue
