aftermarket endlinks?
I noticed my car wasn't feeling as tight around the corners as it used to so I checked under my car and yes the endlinks nut that is connected to my sway bar popped out. (I'm running the Cobb rear sway bar at the stiffest setting). When I attempt to screw the nut back in, the endlink turns with the nut and doesn't tighten well. Are there any vendors that sell aftermarket endlinks that are a little beefier than the stock ones?
Now that I'm getting more serious about setting up for the track I've been thinking the same myself.
i installed whiteline sways on my sti and the endlinks i ordered were back ordered. I ended up installing the sway bars on stock endlinks, auto crossed the car that weekend along with lots of agressive driving and bent a stock endlink
yeah same here! i my car feels so loose, i know white line make some roll center kit
http://www.lancershop.com/customer/p...productid=1147
but i guess it's only for front.does anyone makes for rear??
they will help tighten up the feel in the back, stiffen it up a good bit. I found a pair of perrin endlinks for pretty cheap, right around 110 somewhere online, maybe lancershop.
I just wanted to say too, that is the worst design for bolts that Mitsu ever could have come up with. The stock ones will corrode a little and get really stuck on there, and then it is easy as hell to strip out that allen wrench hole. I just took mine off to upgrade it with the coilovers and all of them stripped out.... retarded..
