Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Can I run Different size sidewalls say..40 front and 45 rear series
Old Nov 9, 2009 | 01:33 PM
UT_Evo's Avatar
Haha, no problem, work is boring, EvoM is entertaining.
Old Nov 9, 2009 | 01:39 PM
Smike's Avatar
https://www.evolutionm.net/forums/ev...-vehicles.html
To re-answer all: No, cant run different sized tires.
Old Nov 9, 2009 | 02:07 PM
cnj4ever's Avatar
in regards to speedo difference check out this page
www.1010tires.com/tiresizecalculator.asp
really informative when it comes to switching it up
Old Nov 9, 2009 | 03:37 PM
LaXGSR's Avatar
Also, to pick between 255/40 or 245/45, take the one that's not as tall. Heard of some people having rubbing issues when going with a taller tire. Just did the calculation and 255/40 should be closer to stock height (tire diameter).
Old Nov 10, 2009 | 09:42 AM
RJones's Avatar
Well it's the OD that affects the drivetrain, correct? So in theory, you could run two different sized tires as long as the OD is the same, correct me if I'm wrong. I know when the Evo was competitive in stock autocross class a couple years back, the national-level guys would run 275/40/17 front and 245/45/17 rear to get more rotation. But that's also not for prolonged periods of time, so maybe it's a bad example...
Old Nov 10, 2009 | 09:45 AM
Smike's Avatar
OD - cant have front and rear wheels spinning at different rates. That fries the center diff.
Old Nov 11, 2009 | 11:05 AM
flyguycfi's Avatar
Originally Posted by UT_Evo
+eleventy billion.
I fully support people that ask easy questions that have already been covered. The search function is like typing "beaver" in google.
Just search titles only. It works a lot better-er.
Old Nov 11, 2009 | 11:20 AM
UT_Evo's Avatar
Then you miss threads that don't have it in their titles... Think of all the titles out there. For example, if I typed "different tires" This thread would not show up.
six40
Evo X Dyno Results
11
Dec 21, 2017 12:50 PM
antics22
Evo X How Tos / Installations
267
Dec 6, 2016 09:40 AM
Teal2nnr
35
Mar 30, 2015 08:46 AM
LOWPROaero
41
May 20, 2013 01:01 PM
samm928
10
Nov 12, 2011 11:21 AM
