HRP Coilover Covers
HRP Coilover Covers
HRP Coilover Covers for Evo X
Link: http://www.gearheadsonline.ca/shop/p...&cat=60&page=1
- HRP Coilover Covers protect your expensive aftermarket coilovers from dirt, sand, rocks, mud, and corrosion. Most aftermarket coilovers come with only a dust boot to protect the shaft of the damper. Unfortunately, it is still common for mud and sand to work its way into the dust boot and damage the damper, often leading to a full rebuild of the coilover. In addition, mud and sand often become trapped around spring perches, making them difficult to adjust, sometimes causing unwanted noises, and in the worst case, leading to the perches becoming seized and unmovable.
- HRP Coilover Covers are made from dernier nylon to provide a cover that is strong and repels water. Elastic bands at the top and bottom keep the covers snug to the coilover, and a velco strip runs the entire length of the cover to allow for easy installation and removal.
- A must have to protect any aftermarket coilovers! Comes in a set of four covers.
- Note: Will not fit stock suspension. Will fit most aftermarket suspension, including T1R, HKS, Cusco, and more. Covers are made to fit coilovers with standard 60mm or 65mm inner diameter coilover springs
Is it safe enough to drive your car in winter with coilover cover?
dD Spikey
EvoX 'For Sale' Interior Styling
106
Oct 16, 2014 03:04 AM
dD Spikey
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 1, 2010 05:43 PM
dD Spikey
Jan 14, 2010 06:15 PM
dD Spikey
Nov 30, 2009 05:50 AM
dD Spikey
Aug 27, 2009 01:05 PM
