How often should I bleed or flush the brake fluid? Re-use old ATE fluid?
Just curious how often you guys are flushing or bleeding the brake fluid? I do occasional track days and autocross, and still am running stock brakes. Last year, I flushed the system with ATE brake fluid. Should I bleed or flush again before the season starts up? Also, if just bleeding the system, can I re-use the remaining ATE fluid (in a metal can) that was leftover from last year? Or is it better to pick up a new can to avoid any moisture contamination issues during storage?
I recommend at least 1x a year (start of the season is a good time) for a flush if you track/autox/get the fluid hot frequently.
Buy new. That fluid likely has some moisture in it. (yes I know it sucks... I hate topping off with a brand new bottle of $29 RF-650, but I keep it as a top off... but use new for flushes.
ETA: this is one of the reasons I switched to the RF-650. The vendor on here claimed that you didn't need to bleed or anything for a year. I decided to take the challenge. I flushed the system last july/august. I bled them a couple weeks ago before the NASA event and the fluid was a little brown, but not terrible and there were no bubbles. Car stopped like a champ all weekend.
Smike
626
Dec 15, 2021 09:03 AM
Smike
63
Apr 29, 2019 07:27 AM
jaycee842
11
May 27, 2016 06:35 AM
lagcisco
Nov 11, 2005 10:53 AM
