coilovers installed, now noises? help!
ok i installed my coilovers and went and got an alignment!! now the passenger front side always makes a grinding/rubbing/screeching sound!! why?? my tire isnt rubbing on anything i already checked like 3 times and when u hear it u will no its not the tire rubbing!! also it makes the noise when im slowing down without the gas or brakes applied!! basically when im coasting to a stop sign/light!! what could it be!
sounds dumb but maybe a rock or something caught in between the caliper/pads? Is it while your going straight or just while turning? What size wheels and tires you go with or are you on coilovers on stock wheels, maybe you need a spacer? Sorry some of the questions may seem basic..... What were the alignment specs?
I would pull off the wheel completely and look at the inside of the tire for wear marks from rubbing. Also look thoroughly while wheel is off at your fender liner (front portion of the liner and rear). Hope this helps....
My guess is either the tire is rubbing on the coilover or the fender liner.
millsyy17
34
Jun 6, 2010 09:11 PM
TeegsMR
May 18, 2010 05:57 AM
EndlessRed
30
Nov 8, 2009 12:43 PM
