TPMS/Valve Stem Question
I haven't been able to find an answer to this. Is there any aftermarket valve stem that can be used with the TPMS? I don't want to put the stock silver valve stems in my new WedsSports cause it will look horrible. I want to find a black or blue one that will work. I've seen quite a few X's with different color valve stems, are u guys just going without the TPMS or did u find compatable aftermarket ones? Thanks in advance for any help.
Sorry if this has been discussed, I searched I swear.
Brad
Brad
All Lancers, including Evos, use VDO TPMS senders, which I don't believe come in any color other than the default aluminum gray. But that sleeve is removable (at least prior to installation) and could be painted separately.
As you probably know, ours cars don't use universal self-learning TPMS senders (which is why you need to go to the dealer [or get a Wheelrite 400 tool] to recode new wheels to the ECU). So I don't see any option besides painting the sleeve if this is really important to you.
Just out of curiosity: Can you install new wheels without sensors and avoid having to match new ones to the ECU (without the ECU / dash warning light constantly bugging you)?
Thanks.
Thanks.
wicked white14
Mar 28, 2013 10:40 AM
