Can't wait to put these on!
thankz bro !!! so u r saying that i can go with this set up ..
no drop or lowerd just stock height and 245/45/18 with 18x9.5 offset 38 will be just fine then with no worries and any problems????
Your rim/tires may rub on the strut. This has already been said. Please learn to read and stop asking the same questions over and over. You need to run a lower offset as the wheel is 1" wider than stock. Just buy the 22 offset and you will have no problems. It is ideal to run the offset on the wheel and not use spacers.
So when you add a spacer of 15 mm to your wheel, your offset changes from 38 to 38-15 = 23mm. Hence, you can use the wheels safely. Hope that clears things up a bit for you.
well guys thankz for the help... i called 5zigen and everything will be okay ... meaning no problem what so ever they already have it on for Evo X with no issues... so i guess it will look pretty much stock how my car looks right now with the BBS rims with 245/45/18 With 38 offset... Just wanted to look nice and simple nothing too aggressive or anything... ill take a pictures as soon i get this rims... thankz...
A 245 width tire on a 9.5'' wide rim will be stretched pretty far. If you turn hard, you will be riding the side wall. On a 9.5'' wide rim, a 265 width tire is ideal. For your rim offset, you'll want to be at +20 to +22 to be flush with the fenders and have good clearance all around.
well guys i changed my mind about this rims... I am now gettin a Rota SVN 18x9 offset 20 color maybe Sport Royal Bronze or Sport Royal Hyper Black and Im also Gettin a ChargeSpeed Aero Kit Type 2 OMG!!!! Cant wait...... ill post the pics as soon as i put it on ... thankz guys now instead of ME spendin alot MONEY for sets of rims now i got two Item... for a good Price.... Wooo hooo!!! ...
your taste in mods are questionable.. the chargespeed kit is fugly no offense.. but if you do want the kit.. you want to go 18x10 +20 on the rims so the kit does not make your rims look puny..
if you get a kit.. i'm sure you're ok with modding your fenders.. go all out and do 18x11 rims
