Can't wait to put these on!
Offset of of 38 is going to look weird, assuming it even clears the brakes.
After an ultra fast lol-google, according to Wheeldude, the Grids at +38 wouldn't fit the X:
Now, these ain't Grids, but the same answer might apply.
The 18x9.5 +38 model will not fit the Evo X. The Rota Grid has a ton of concave and will require a lower offset to clear the front Brembo calipers. We make this model in 18x9.5 +20 fitment specifically for the Evo X
This is from the %zigen website... 18×9.5J ●12/ ●22/▼38/43
Do you think 22 offset will be good????
●Clears Silvia, Skyline, Fairlady Z, Supra big caliper
▲Clears Impreza OEM 4POT caliper
▲Clears Impreza Brembo caliper
■Clears Lancer Evolution Brembo caliper
▼Clears GTO fitment
▼Clears GTO fitment
▼Clears GTO fitment
▼Clears GTO fitment
I forgot to mention to you guys that 2008 My Evo X MR is not lowered or drop still stock .
So i want to know and make sure that DO YOU GUYS THINK THAT I WILL BE FINE WITH THIS SET UP 18X9.5 OFFSET 38 WITH BRIDGESTONE RE960 POLE POSITION 245/45/18???
PRO RACERS GN+
PRO RACERS GN+
Did you get a killer deal on the +38's or what? You'll certainly improve your odds by going with a 245 tire but why buy wider wheels to run stock tire size? Among those options I would have done +22.
If you use a 10mm spacer then you could run 265's and you come out pretty much flush with the wheel well (I have +28).
lol!!! i did .. and my mechanic said that the tires that i have will strech and will fit fine.... So should i go 18x8.5??? come on guys help me out .... 18x8.5 and 18x9.5 is only a inch differents right ????
so i think i should be fine then .... right ???????
