Noise from KW helper spring
Just installed KWs on my other car and the passenger side rear helper spring makes a noise when going from loaded to unloaded or vis versa. Noticed it when I was driving. Tested it by puting that corner on a jack and loading and unloading that wheel.
Is there something I can do to get rid of this? The other 3 do not have the problem.
Are you where you can talk about it now?
I think the perch (the part that adjusts the ride height) is tight. I did sprey some tri flow on the spring but have not diven it very far since then so it might have not "worked in". Will drive the car tomorrow.
Tri flow did not help. The noise is a binding noise...like springs on an old box springs.
I plan on jacking it up and loosen everything, clean and lube it and then tighten it back.
MFactory
Evo 'For Sale' Suspension / Brakes / Handling
31
May 30, 2017 11:45 PM
lghtngyello03
58
Mar 14, 2016 02:05 AM
Terton01
Jan 18, 2012 11:54 AM
