Bridgestone RE-11... Opinions?
I definitely recommend considering the Yokohama Advan Neova AD08s as well.. However, at this level of tires, you can rest assured that you will be extremely satisfied with either the RE-11s or AD08s. It isn't always true, but in the case of these two tires, you truly do get what you pay for.
The Advan AD08s are great tires too. I think there's a distinct difference between them and the RE-11s though; I think the AD08s may have more ultimate grip (based on others experiences, never tried them myself), but the RE-11s ride better.
Pure track car? Try out the AD08s. Street use? RE-11s. IMO.
IMNSHO, the RE-11 is the best street tire that you can currently buy.
And, it works quite nicely on the track. Almost a DOT R-compound. Just make sure you have enough negative camber.
Don't expect more than 8-10K miles on the street, much much less if you're tracking.
Likely AD08's have the slightly better grip based on tests and reviews in the dry, although in the wet the more responsive turn in can make them trickier in the wet at the limits but it really depends on how the suspension is setup. Tire wear seems in line for them to last around 15k miles, although at -2.5* front camber the inside edge is going to be the first spot to wear out, likely -2.0* would make it last a bit longer.
I'm running AD08s and they are great. I had the RE01R before and liked that as well. Can't go wrong with AD08 or RE11 - both are low noise, high grip tires.
The other tires that can grip with these tend to be not as friendly on the street (more noise, harsher ride).
I settled on the Yokohama AD08 myself but those Bridgestones were a close 2nd. If they had the right tire sizes in 19" the Dunlop Starspecs offer almost as good performance for quite a bit less cost. You can't really go wrong with any of those three for a dedicated summer tire on a car that see some track time.
Loved them, very sticky tires. Only thing I can consider a downer (not really a downer tho) would be how quiet they are, I like to rely a bit on squeal when theyre about to break loose on track. Oh and despite tread rating, if you drive a bit conservatively, they last for quite a long time for daily driving!
Since I'd be doing primarily street driving with some track days... it seems like the Bridgestone RE-11's are the best choice.
Actually, for max street grip, I'd say the slightly softer sidewalls of the RE-11s might make them better than the AD08s in ultimate grip as they are able to absorb the bumps.
There's a set of corners around work that's slightly bumpy mid-corner. On the stock Yokos, the car would skitter across the surface due to the overly stiff sidewalls. When I had the RE-01Rs on, the sidewalls were able to absorb the imperfections and maintain grip.
From my experience, Yokos tend to have super stiff sidewalls and get noisy, and Bridgestones are a step softer in the sidewalls and stay quieter. This spans from my driving on Yoko Intermediates waaaay back in the day (~1998). They rode stiff and got loud as they wore out. From there, went to Bridgestone RE730s, then three sets of S03s. Bought the Evo with the stock Yokos which were the stiffest tire I'd ever been on, then to RE-01Rs and now RE-11s.
The AD08 is actually very good on the street. The AD07 had some issues but they have a new compound on the AD08 which make it very good. Quiet and sucks up bumps very well equivalent to RE11 - way better than the stock A13 tires. The A13 IMHO sucks for grip and comfort.
Ultimate grip is a tad higher in the AD08 than the RE11 but the RE11 is more street friendly as always. Between the two, it will be really hard to notice the difference.
As for Sumitomo HTR Z3... those arent even in the same class. Great for your daily driver but that's about it.
Steve_P
Jun 27, 2017 05:25 PM
NoReason
14
May 8, 2015 01:45 PM
jerastan
For Sale - Wheels / Tires
17
Apr 16, 2013 07:26 PM
NeoGearX
29
Feb 16, 2012 03:19 AM
dabeast
42
Feb 25, 2011 04:09 PM
