Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
I need your advise on Brake pad
Old Jun 7, 2010 | 12:58 PM
love67's Avatar
Hi guys,
my stock brake pad is pretty going to wear out soon and i need to replace them for my next track day. I'm new to the evo and tracking thing, so i need your advise on brake pad because i really don't know what brake pad to get is suit me the most.
I'm looking for a pad that running fine on the street and also running good on the track, is there a such thing? please recommend me some.
thanks
Nick
Old Jun 7, 2010 | 01:00 PM
goofygrin's Avatar
no such thing if you don't drive like a grandma on the track.
There's a sticky thread in this forum with a ton of good info. Read it.
Old Jun 7, 2010 | 10:38 PM
Ah10's Avatar
Originally Posted by love67
Hi guys,
thanks
Nick
honest answer: no such thing
my recommendation is
Street pads: Girodisc Magic pads or Project mu
Track pads: Reybesto ST43
Old Jun 8, 2010 | 09:40 AM
Kracka's Avatar
The closest mixed-use pad you're going to find, in my opinion, is the RacingBrake ET800B. It will be a little noisy and dust on the street, and not take the heat like a true track pad so keep this in mind.
Old Jun 8, 2010 | 10:27 AM
weneversleep's Avatar
CL RC6E. Expensive, but worth it.
Old Jun 8, 2010 | 11:01 AM
Guru's Avatar
I'm going to give the Ferodo DS2500's a try.
Old Jun 8, 2010 | 06:14 PM
manchi's Avatar
Carbotech Bobcat 1521 for street.
Carbotech XP10 for track.
Old Jun 14, 2010 | 07:39 AM
cescboom's Avatar
Mine have held up for two track days so far.
Old Jun 14, 2010 | 09:53 AM
mlomker's Avatar
That's what I run but I do drive like a grandma. I think they call that being a track novice and not (irresponsibly) driving beyond your ability.
Old Jun 22, 2010 | 11:31 AM
EVOBrakes's Avatar
Yes, Seperate track and street pads is best. Either XP - 10's from carbotech or DTC - 30 from hawk or something similar for track and whatever you feel you want for the street, there are tons of flavors.
- Joe
Old Jun 22, 2010 | 12:16 PM
mlomker's Avatar
Do you know anyone that has used the XP8? They say it should be suitable for anyone short of HPDE experts and yet should still be safe to drive to the track. I basically only drive my car to/from the track so it might be a good fit.
Old Jun 22, 2010 | 12:17 PM
Nsomniac's Avatar
EvoM Administrator
- Joe
I strongly agree with separate pads. I even switch off for auto-x, and track use is much more demanding/heated. It's only a 45 minute job (max) for all 4 pads anyway, and in the long run it'll probably be cheaper. Just my .02
Old Jun 23, 2010 | 05:19 AM
love67's Avatar
what do you guys use to push out the pins on the brake? im having hard time to push out the pins because i don't have anything that fits in the holes, or i will scratch the brake...
Old Jun 23, 2010 | 07:49 AM
EVOBrakes's Avatar
Make sure you push down the retaining spring while you are trying to push the pins through, it will help to release pressure. I use one side of needle nose pliers. just about anything will work. Pulling it from the back side is easier anyways.
- Joe
Old Jun 23, 2010 | 09:34 AM
Nsomniac's Avatar
EvoM Administrator
I use a concave headed nail set. It works perfect.
