Megan Racing Lowering springs?
agreed. But there are camber kits for both the front and back of honda/acura's. I could find the links if need be to prove that to you. Given I really dont know that much about awd cars or evo's. That I will admit. When it comes to the rsx, I know more about it and how to mod it then anyone in my area. I took an otherwise stock 06 type s and ran 14.4's all day with only $500 in mods to it. I do have learning to do on the evo and awd cars, and I am as I go along.
LOL did you even read what Chu said in his most recent post..? We know there are camber kits out for Honda's and Acura's already but Chu mentioned there aren't any for the EVO, mind you you're on an evo forum so nobody cares if there are Camber Kits for Honda's or Acuras. Furthermore, like Chu said, you're comparing two completely differed suspension Geometries. Universal facts aren't as universal as they used to be. As i've mentioned before there really isn't enough travel room on the stock shocks no matter what you do with the camber... change teh camber all you want. 2" drop and you'll be in for a rough ride, less you decide to grab the MR Bilsteins.
On top of that, some research shows that lowering the X past a certain point increases roll... you try to fix that with Camber, please.
But we're off topic, OP, as i've mentioned before i would really go with Swifts over Eibachs. other than that if you can wait a couple month's i'd really go with the package that GTworx is going to put out. It's a Spring/R sway bar combo. Andrew at GTworx is super knowledgeable and is my go to guy for any suspensions questions. I'd ask him.. IMHO, Eibach's are terrible in terms of performance but great in the look department.
I am not attempting to. But it also isnt totally impossible. Lowing a car lowers the center of gravity. However if you lower it to much and dont fix the chamber your car essentially drives on the very inside of the tire which isnt good for handling. I agree with that, But if you put a chamber kit in it to fix this the tire will have more contact on the road thus improving grip and handling
The problem with dropping the EVO with springs 2 inches is that you do not have enough suspension travel for the shock to work well. The result is poor handling and ride quality. The suspension geometry is definitely also a problem, but I'd say the lack of travel is more the limiting factor when lowering on just springs.
- Andrew
OP, this would not be an informative thread when theres are comments that are senseless.
Andrew, thanks for chiming in. I look forward to the release on the GT Worx setup. I have a few friends waiting for it!
I've looked all over this forum and have found nothing on these springs. I found out that they have a 2" drop in the front and a 1.75" drop in the rear. The spring rate is 5.0 for the front and 4.5 for the rear. I found 1 person over on the evoxforum that has them, they look good. Really low though, I would also imagine that with that spring rate they would ride rough. I'm not really interested in getting coil overs, I just want the "look", no track use for me just daily driving. Any input would be great.
Tire wear is not the issue and shock valving is not the issue. You can correct the alignment without buying anything, the OEM adjustment is enough.
The issue is that the car will be sitting on the bumpstops up front, and in a turn your spring rates will spike extremely high and the car will understeer. The shock simply can't compress any more. Add a mid-corner bump into that and the car will simply bounce out from the apex since there is no compliance. But even on a smooth circuit or road, it's not going to handle well because the outside front tire will be overloaded just from body roll. Valving can't really fix this, it's a travel issue.
- Andrew
- Andrew
^^ OP, i'd take it from Andrew. Has a great rep in the evo community for knowing his suspension info etc. Hell, i'm waiting for him to finish that combo package and may hold out on buying the HKS hipermax's non sport just for their product as it's R&D'd very thoroughly.
I agree a 2" spring drop is a bit extreme, unless you are going with coil overs, I really would like to get rid of the wheel gap. I have not seen any of the Megan products first hand, but by the pictures that I've seen I have to agree with go_dlee about the quality. It seems to be lacking in that department. Getting some good info from you guys.
My GSR handles WAY better after having my H&R springs / Whiteline RCA kit / Megan Racing rear lower arms installed.
IMO Swifts are soft, expensive, and give a weaksauce drop. Although I can't speak for Megan Racing springs, the quality of their rear lower arms are excellent.
RCA.jpg?t=1280605395
Will coilovers fix this problem?
- Andrew
- Andrew
Most good coilovers let you run lower ride heights and still maintain an acceptable amount of travel. 2 inches is low enough that I would definitely do the Whiteline front RCA kit AND I would be running firmer rates at that point.
And riding on the bumpstops is deceptive....it can feel fast on a smooth road but at the limit that spring rate spikes and you'll find yourself overloading the tires sooner.
- Andrew
- Andrew
