Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
pros & cons of wheel spacer?
Old Jul 26, 2010, 04:50 PM
3VOIXMR's Avatar
hey guys, need your opinion, i'm planning of putting a 20mm spacer on my stock bbs so it would look a little flush, i was told that it has a disadvantage when a spacer is put on the wheels, it might bend the studs, is that true? did anybody had problems with these spacers? thanx for your input on advance.
Old Jul 26, 2010, 05:05 PM
thekhmer's Avatar
if u go cheap on the spacers there are alot of problems you'll run into..i would get those new gen spacers that you just bolt onto your old studs and they have locks and new studs pressed in for ya..those seem the safest
Old Jul 26, 2010, 05:07 PM
evoxxx19's Avatar
Ive been looking for some good spacers for my bbs as well, best site that has them?
Old Jul 26, 2010, 05:08 PM
On2
On2's Avatar
I have never heard of studs bending.
The main disadvantage is more load on your wheel bearings. They will wear quicker.
Old Jul 26, 2010, 09:05 PM
Evold_one's Avatar
I have had Ichiba type II on my X for 5k miles now with absolutely no issues. No need to change studs or anything like the type I spacers. Mine are 15mm.
Old Jul 26, 2010, 09:17 PM
caliboy01's Avatar
daily use- not bad
race- for (me) very bad
Old Jul 26, 2010, 09:41 PM
ZK
ZK's Avatar
You should do a search on it... The bolt-on type spacers that come with new studs should be fine.
Do not put on a 20mm spacer that uses the stock studs! The stock studs are not long enough to be used with spacers.
Old Jul 27, 2010, 07:20 PM
3VOIXMR's Avatar
Thanx for all the opinions! Appreciate it!
Old Jul 28, 2010, 04:01 PM
ImEv0's Avatar
simple.
pro-gives u that aggressive stance.
con-everything mentioned above. to what extent, i do not know. i heard at high speeds 100+ steering shakes slightly.
Old Jul 28, 2010, 10:22 PM
FerdEVO03's Avatar
I'm running Ichiba 20mm spacers with no issues for almost a month now and have been daily driving my car....I got them at Touge Factory. I'm on Swift springs and didn't have to roll any of my fenders nor modify the inner wheel lining. I've been checking for any signs of scraping every week and found none so far with plenty of spirited driving.
With these spacers, it'll make a big difference in the overall appearance of your car. I was actually planing on getting new Wheels till I saw how sexy these BBS can be if you just pop them out a little bit..
If you do get these, be sure to post pics of your WW X MR!!! I wanna see a white one with these on.
Old Jan 21, 2013, 09:11 PM
superlemonevo's Avatar
can i put on wide wheel adapter 60mm?
anyone tried 60mm wheel adapter on evo? i have purchased hub centric adapter, 60mm and i would like to have widebody as well, but before deliver my car to widebody workshop, i would like to know whether it has serious safety concern. will that cause serious damage on the wheel hub or suspension?
someone here can give me advice ?
Old Mar 18, 2013, 09:35 AM
3VOIXMR's Avatar
I wouldn't use a 60mm spacers, If i have the$$ I will get wide wheels instead.
Old Mar 18, 2013, 10:07 AM
3VOIXMR's Avatar
Can anybody post here how long they've been using their spacers, issues, brand, how many mm, input?, thanks.
Old Mar 18, 2013, 02:10 PM
heavyD's Avatar
I used 5mm spacers (on stock lugs) my old SRT4 and while I never had any issues I found that the lug nuts would never stay torqued. I would have to re-tourque every 3-4 weeks. Don't think I would go that route again.
Old Mar 22, 2013, 08:44 PM
Snagtooth's Avatar
I've had 15mm spaces machined from Alumn. on stock studs for over 15,000 km with the stock tire and have had no issues.
Quick Reply: pros & cons of wheel spacer?
