Cosworth Streetmaster Brake Pads (Any reviews)
So apparently there is a new pad out there for the X made by Cosworth. To me they seem to be in the range of the Ferodo DS2500 and the Project Mu B-spec / HC+ .
I wonder who actually makes these for Cosworth though?
Cost is actually a large point where front and rear set go for about $250-275.
![](http://www.maperformance.com/products/cosworth_BrakePads.jpg)
Manufactured in the UK, Cosworth brake pads feature a 1.5mm granulated inter-layer which not only serves to act as a shock absorber, helping to reduce stress on the rotor surface but triples bonding strength, diminishing edge lifting. To reduce the bedding-in or seating-in time - this is the time it takes for the pad and disc to adapt to each other - all Cosworth brake pads are heat seared. This process heats the friction material to in excess of 600 degrees C , toasting the surface , greatly enhancing the performance the first time that the driver applies the brakes. Scorching pads also significantly reduces initial fading - fading increases the necessary force and pressure required to maintain the deceleration of the vehicle. Cosworth's brake pad range offers exceptional performance without compromise.
* Superior bite from cold
* Silent running technology
* "Vee" groove for fast debris clearance
* Fade resistant
* Premium grade friction material
* Consistent & predictable braking patterns
* Medium-hard sports pad suitable for heavy duty/fast road
* ECE R90 approval
* Superior bite - 0.5 Mu friction coefficient virtually from first pedal
* Strong brake effect up to 650 degrees C
* Chamfered edge to avoid lifting
* Fitted with premium quality shim hardware for silent braking
* Durability factor 6.5 with rotor minimal rotor abrasion
* Produces consistent, predictable braking performance
* Fade resistant
* ECE R90 approval
Smike
626
Dec 15, 2021 09:03 AM
Smike
Jul 16, 2017 02:00 PM
