alignment? flip the camber plate?
Took the car to the firetone and got lifetime alignment ($179.99 with $30off discount = $149.99), not bad at all. But the tech told me that the front camber can NOT be adjusted!? He even took me inside the shop and show me their screen, the machine does say "Lancer Evolution X front camber unadjustable"... Any one knows why? Btw, I did tell the tech to look for the bolt, but he couldn't find it...
so my result is:
Front
Left : Camber= -0.7(original); Toe= 0;
Right: Camber= -1.1(original); Toe=0;
Rear
Left: Camber= -1.1; Toe= 0.17;
Right: Camber= -1.1; Toe=0.10.
Can anyone specify where the front camber bolts are? Pic will be highly appreciated!!!
PS: never mind, just found the post and wrote the info down. Gonna bring it to the firestone and show to the tech next time (LIFETIME alignment is wonderful lol)...
so my result is:
Front
Rear
Wider wheels has NOTHING to do with alignment. A wider wheel does not in any way affect camber/caster/toe... The alignment is at the hub as said, the hub has not changed and even if it moved out or in, it doesn't change the suspension metrics, only contact patch.
so my result is:
Front
Rear
so my result is:
Front
Rear
I second that. Where I used to live, I had friends at the Honda dealership who would always help me out with things that required special equipment. Then I moved halfway across the country
Alignment was done today... thx for everyones input.. see pictures of alignment specs. To keep a long story short, if you buy a new evo an alignment should be on your list of things to do. My car was out of alignment with 30 miles on it .. front left was way out.
Anyway, I went -1 0 toe all the way around. By loosening up the bolts on the struts and tightening again we were able to get it dialed in.
I went with stick on weights on the inside of the wheel see pictures, you can't tell there on unless you are looking for them.
The tire changing system they used had plastic parts.. no metal to scratch up my wheels. My wheels didn't have a single mark on them.. I was worried about that.
Car drives noticeably better... and I got the discount
xspsi4
41
Aug 12, 2013 01:39 PM
triguy
14
Dec 29, 2008 03:27 PM
DSMEVOLUTION
Mar 31, 2008 08:55 PM
