alignment? flip the camber plate?
I'm getting my conti DWS put on Sat morning and an alignment.
Should I have them flip the camber plate on the front wheels?
I've got rsb, everything else is factory. Will swap springs to swift spec r's in the next couple months.
Just changing wheels does not require an alignment. Alignment is set at the hub. If you have more than 1 year with current alignment, its not a bad idea to get it checked from bumps/use. Otherwise, if just doing a wheel swap -- not required.
*Required* -- what are you using the car for? Flipping the camber bolt to add camber for ____?
Your exactly right...
Firestone has lifetime alignment for $180
I just put in a rear sway bar, and am taking it to them on Saturday to swap out my tires.
I figure I might as well get an alignment while I'm there....from what I've read the factory alignment is poor.
I'm using this for daily driving. No auto X, ... although I do live a bit out in the country and our roads are not flat... kinda 50/50 straight/curvy, hills.
I'm asking because I want to be able to tell the alignment shop what to do... based off of everyones experience here... + if I know what there doing then I will have a good reference related to changes I want to make when I put springs on.
...or do I just tell them to align it to factory specs?
a stock spec (i know there's a wide range) alignment is perfectly fine for car that are soley street driven. running -2* front won't result in longest tire life but it also wont eat them up that quickly either.
~-1.5* front and -1* rear with as little tow possible is prudent and adequate for street driving.
getting as much in front with the bolt in its original position and then half a degree less in rear is a good street/autox setup IMO. flipping the bolt will get you greater than -2*.
this is basic info and i am by no means an expert.
If you do not drive aggressively, do not need to tuck-in a big fat wheels, or attend track/autocross events at all then there really isn't a reason to change it from the factory spec. You will not feel any difference at all driving to work unless you are taking some spirited turns. If you don't track or autocross set it to the factory spec -1.0F/-1.0R and 0 toe. I ran my last tires on factory for a few autocross events and a couple of track days and it was still fun. I am now running -2.6/-1.5 and there are no real issues at all but of course my commute is only 14 miles one way a day and what little wear is there gets evened out at the next event.
Took the car to the firetone and got lifetime alignment ($179.99 with $30off discount = $149.99), not bad at all. But the tech told me that the front camber can NOT be adjusted!? He even took me inside the shop and show me their screen, the machine does say "Lancer Evolution X front camber unadjustable"... Any one knows why? Btw, I did tell the tech to look for the bolt, but he couldn't find it...
so my result is:
Front
Left : Camber= -0.7(original); Toe= 0;
Right: Camber= -1.1(original); Toe=0;
Rear
Left: Camber= -1.1; Toe= 0.17;
Right: Camber= -1.1; Toe=0.10.
Can anyone specify where the front camber bolts are? Pic will be highly appreciated!!!
PS: never mind, just found the post and wrote the info down. Gonna bring it to the firestone and show to the tech next time (LIFETIME alignment is wonderful lol)...
so my result is:
Front
Rear
Just up there on the top lol:
https://www.evolutionm.net/forums/ev...fications.html
