AST 4100 or KW v3?
AST 4100 or KW v3?
Hi guys,
Im looking at these 2 coilover for my evo X and i still don't know which one would suit me better, so i was wondering if you guys can give me some advise? My car is my daily driving car but I do go to the track when the event is good, i also like to canyon driving too, so which one will be good for me? please feel free to say anything.
thanks
Nick
thanks
Nick
Either would proably make you happy.
There is a learning curve with the KWs because of the double adjustment while the ASTs are single adjustment...so easier to adjust but limited.
YOu could consider Robi Spec's KWs that will be custom valved and springs.
AST will give you any spring rate you want. Robi has but a lot of testing into his setup. There was some R and D with the ASTs but not sure to what level.
Both are quality products.
Pure longevity the Robispec/KW SS casing and twin tube has an advantage. (fewer wear parts)
Robispec/AST monotubes have less weight and cool better.
Robispec/KW double adjustable (can be a disadvantage too lol)
Build quality and parts availability exellent in both cases (helps when there is a problem).
RObi
RObi
The KW twintube base valve system can work better than a monotube in the under 1"/second range and this supplies better "insantanious hydralic resistance to movement" and allows a softer spring rate (also the stiction forces are less so the damper/spring system feels smoother.
Monos have a higher initial "breakout force" and so they usually use a bit higher inital spring rate to stabilize the car.
So for the applications most often encountered by most here, what are do you generally recommend?
Daily driver who wants the car lower w/no loss or a bit of improvement in performance without loss of ride quality?
Sometime/occasional track or auto cross guy whose car doubles as daily driver?
Mostly track guy who may use car occasionally or never as DD or lives where roads are smooth?
How about if any of these have to deal with very bumpy roads/tracks?
^^^ thanks for keep asking question, so i can learn more! but rightnow money is really important fact to me... the kw v3 and ast has $450 different...so i don't know if go with the lower price one(KW) or with go AST which easier to set up (which i really want). i know both of them is good so right now is lower price but higher to set up and higher price but easier to set up.
what do u guys think? and i don't know how does the double adjustment works so i don't know if i can tune it right...
thanks
Nick
thanks
Nick
I just cant help , to like the AST better with my previos experience. Also since it easier to set up for rookies , has less room to ruin the ride ...
And we know that is happens , when someone just start to dial coilovers in a way he thinks the ride will be faster... LOL
