parts to expand my alignment capabilities
Just got my first alignment done the other day, but before I went I read the notes on stock alignment from here that's stickied in this section. Apparently there are a few things that aren't adjustable:
Front:
camber: not adjustable
caster: not adjustable
toe: adjustable
Rear:
camber: adjustable?
caster: not listed
toe: adjustable?
There were a few things I wasn't sure if they were adjustable or not.
Main question: Are there aftermarket parts I can get to adjust all 3 dimensions of the front and rear wheels? Where's a great place to look?
Front:
toe: adjustable
Rear:
camber: adjustable?
caster: not listed
toe: adjustable?
You can get coilover with adjustable camber plate, which allow you to adjust your front camber, or you can get a camber bolt kit but it won't allow you to adjust camber as much compare to the camber plate, you don't have rear caster only up front
like GTworx said, you can flip the bolts to get more camber. I am on completely stock struts and bolts. have close to -2 both side front, 1.5 both sides rear. makes a HUGE difference esp with wide wheels aggressive tires
I had my X lowered a bit and with flipping the bolt I could get over 2 degrees camber in the front, which is more than enough for a street driven car, unless you're into show bussiness running 20x11,5 +8 OMFGwheels and you need 7 degrees of camber to make them fit in the first place.
idriveanevo
11
Jun 16, 2009 09:45 AM
ultimatesteve
25
Jan 3, 2007 02:26 PM
