Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
looking for better lowering spring
Old Feb 13, 2011, 11:17 PM
chendu1280's Avatar
my evo x mr is currently lowered with tanabe GF210 lowering spring...but i dont like it...the rear drops more then the front did...what other lowering spring drops lower then the GF210?
Old Feb 14, 2011, 06:15 AM
Kracka's Avatar
I'm very happy with my Eibach Prokits. They ride great and look nice.
Old Feb 14, 2011, 08:21 AM
GTWORX.com's Avatar
*cough* look over here
https://www.evolutionm.net/forums/ev...installed.html
Old Feb 14, 2011, 11:31 AM
WM_EVOX's Avatar
The Swift Spect-R on my MRT feels pretty nice. Works great with the stock Bilstein shock and not too low to scrape everywhere.
Old Feb 14, 2011, 11:34 AM
chrisw's Avatar
IMO, if you want a better lowered suspension setup, just save the money and buy a set of coilovers. You will be much happier in the long run.
Old Feb 14, 2011, 06:39 PM
tlsole's Avatar
Same here, looking for the "best" spring for its value.. Im leaning towards Eibach, because of the price and the fact that i dont track the car or ever push the car to its limit..all i do is sprinted driving and occasionally take some corners when i see some good ones (I live in Houston, its all flat land).. I do plan on getting coilovers later down the road but for the meantime I rather spend that money on a new turbo haha.. But alot of people seem to like swift's..
Edit: i suck at spelling..
Old Feb 14, 2011, 08:04 PM
dirtyb's Avatar
I'd stay away from Eibach. They will certainly slam the car but they won't do much for performance. Go with swift or H&R they produce much better sprints from what I've seen.
What are you looking to get out of the setup? What do you use the car for?
Old Feb 14, 2011, 08:30 PM
chendu1280's Avatar
i use my x just as a street ride...so i wanted more for show then performance, i dont track so im not worried about that
Old Feb 15, 2011, 07:19 AM
tlsole's Avatar
^ If thats the case, you probably would like the Eibach's..the drop is nice.
Old Feb 15, 2011, 09:49 AM
Evod350z's Avatar
i got the eibach prokit. I love the stance but its slightly bouncy but the looks makes up for it.
Old Feb 15, 2011, 07:46 PM
Phantomevose's Avatar
is their only one set of swift spec r's that work for the mr and gsr? i have a 2010 SE so i have the mr suspension and i see some springs work with one but not the other.
Old Feb 15, 2011, 08:01 PM
beetle_orange's Avatar
the swift sport should work as well for you.
Old Feb 16, 2011, 06:41 AM
1st"EVO8"'s Avatar
I'm also in the market for some new lowering springs for my evo 8 gsr. I hear the bilstein/swift spec-r combo are the crowd's favorite...
Old Feb 16, 2011, 06:49 AM
High_PSI's Avatar
I would disagree, I had two sets of coilovers, a lowered VIII suspension and now Swift Spec R's on my MR, by far and away the swift spec R's on Bilsteins is the best suspension setup I have ever had. Coilovers are just WAY too stiff and the costVs. reward you can't just go out and spend a grand for some KYB garbash or even D@ monotube Chinese B.S. you really need to spend some Serious cash to get a peoper Coilover setup.
Swift Spec R's and Bilstein HD's.
Old Feb 16, 2011, 09:37 AM
WM_EVOX's Avatar
I believe all aftermarket springs fit all trims of EVO, whether it's GSR, SE, MR or MRT.
Quick Reply: looking for better lowering spring
