Car shaking please help!!
so i threw on some 18x10s, -1 degree camber in the rear and lowering springs. When my tires were mounted i had them balanced obviously, and when i threw on the springs and camber i had an alignment done.
After the alignment was done the car and steering wheel would shake under heavy acceleration, or when i was cruising about 65. Anyone have any idea whats wrong?
i took it back in to the alignment shop and they said its 85% chance that my wheels need to be balanced again. Before i do this does anyone else have any other insight....PLEASEE!!
^ The place I went to just a week or so ago for similar only charged me $34 to check balance and re-mount all bad ones and rebalance them three. It was money well spent. Tell the place you're a trackhead (true or not who cares) and they'll likely give you some discretionary discount pricing.
rebalance them. I had the same problem even though it was balanced at a friends shop, but i took it to firestone and it turned out that one wheel was not balanced it was off by alittle but caused huge vibration. after the rebalanced i have no more problems.
I had my stock Advans mounted on some Rota grids. Everything was fine the day I left the shop, but after a few runs into Manhattan I was getting a WICKED shake in the steering wheel at 80 MPH. Popped the wheels off and threw in some hub rings - didn't make any difference...
Wound up going back to the shop to have them re-balanced and it turned out one of the front tires was off by a half an ounce - the exact amount of one weight... Must have lost one somewhere...
Not sure how I lost it, but once they put it back on I have no vibrations whatsoever!
beasters
24
Nov 9, 2013 12:50 PM
Ralliart367
39
Jan 29, 2013 07:37 AM
gmed
21
Jan 15, 2009 09:31 AM
