3-Wheeling
Do you want it on the ground? Ideally yes. Is it bad it isn't? Not at all. You're honestly probably not losing much for any normal driving/HPDE/basic Autocross.
What Iowa said is exactly right:
It's a combination of forward weight transfer (entering corner), your stock swaybars, and your 14k rear springs.
1) Lower the weight/weight transfer of the car into corners
A) Decrease the overall weight
B) Go in to the corner slower and don't slam on the brakes as hard going in to it, learn to manipulate the car's weight.
2) Replace your stock swaybars
3) Get a lighter spring rate in the rear coilover setup.
Also don't know why ZK said what he said... The whole reason the X handles so well is because (well, many reasons but) S-AYC corrects by noticing that the inside rear has no traction and diverts power to the other 3 tires meaning no power gets lost to the outside rear tire. Unless the S-AYC is a broken system and I misunderstood how it worked all this time... That's how my LSD on the MINI and the DCCD worked on the STi.
Um. The first thing I said was: "It's a combination of forward weight transfer (entering corner), your stock swaybars, and your 14k rear springs." [emphasis added]
With that said, given that lifting the inside rear at corner entry really isn't that big of a problem, if the OP is happy with the car's balance the rest of the time, I wouldn't ruin it just to keep the least important wheel on the ground at corner entry.
Of course, the S-AYC system is more than just a particular collection of separate devices. Are you suggesting that the X also has a BMW-like limited-slip system on the front? (i.e., brakes are applied to any wheel with little to no grip; a Mini is now a BMW, so that's probably what you mean when mentioning the Mini) Given that some people actually replace the front helical with a 1- or 1.5-way suggests to me that there is no secondary limited-slip device on the front of an X and I don't see anything about such in shop manual.
Solving the problem of inside-front slip with a harder-locking center is very sub-optimal and should not be used unless there is absolutely no other option. If you lock the center, when the inside front starts spinning at exit, the outside front has no choice but to slow down. Hello power-on understeer city.
My point was that ZK is mentioning something that doesn't matter. The system is supposed to detect that the inside rear tire has lost traction and divert power (if any is given) to the other 3 tires instead.
I apologize. I should have been more clear.
And no, on pre-2011 (I believe) R56 MINIs "S" models (Clubman and Cooper) there was the option for DSC (which includes the system you speak of) and an option for a true mechanical LSD or both. Most enthusiastic drivers turn DSC off all the time, hence you'll see MINIs with stickers that say "DSC Always Off!" on the back.
No problems, man. But if I had been you, I would have just corrected ZK instead of continuing the line of thought. The AYC doesn't give a rat's tushie about lifting a rear wheel under braking at corner entry, which is what this thread is about. The S-AWC system might care, but the fancy rear diff doesn't. And, as I said above, if you're lifting the inside rear at corner exit on tarmac, then you have problems that are so serious that we are not going to be able to help. Even more, I am willing to bet my first-born (who is a total PITA, anyway) that no-one could set an Evo X up so badly that lifting the inside rear at exit is possible.
My bad. I swore I saw something about a sway bar, but after a quick scan, I didn't notice it. I fully agree with your statement though.
Another thing is if the OP didn't cornerweight the car or set the springs with excessive/uneven preload then it may cause the rear wheel to lift excessively.
WTB[Northeast]: (NY) Evo 8 SSL parts:
Evolution Z
Feb 7, 2015 06:35 PM
SsZERO
30
Nov 4, 2008 07:59 PM
