Best Wheels for performance?
Hey everybody, so I'm wondering what the best wheels are for performance on the road. Specifically, im interested about weight, I hear the Volk TE-37s are pretty good in that department.
Also, what is the best size for performance? 18inch or 19 inch? I know 19s are heavier (more unsprung weight), but it also means less sidewalls for the tires to flex under cornering, right? Same goes for rim width: 9.5, 10, or 10.5? Unsprung Weight vs contact patch?
Last but not least, offset and camber. I would imagine the lower the offset, the better the handling characteristics, since the car would have a wider "stance." And I'm guessing a tad of camber can't hurt either.
Anyways, all noob questions im sure, but would appreciate any help.
I think most of your statements are true. I don't know that the handling of a 19 makes up for the weight -- in fact I'd say it rarely would. The contact patch is far more important than the flex of the sidewall in terms of handling too, wider is better.
It depends on what you're doing too, autocross, rally or dragging.
"The best" will be relative to your sport and budget. Volks are great for moderate budget, but you can get magnesium and carbon fiber rims that are far superior for 3-5x the cost.
tkromer is right, lets start with the intended usage of the car. And no, 19's are too big. Generally speaking at this level of the car, you want wheels that are just big enough to clear the brakes and that's it.
And I actually don't think going with huge 10.5 inch wide wheels is a great idea all of the time, but that's just me.
- drew
- drew
I agree going too big too early will hurt you, but it's not going to feel like you threw an anchor out of the car either.
As your engine output goes up, you need to increase your contact patch and take the slight weight penalty of wider wheels and tires as a compromise or start to feel like the car is overpowering the tires on corner exit. When I tested some 265/35-18 Bridestone RE11 tires on 18x9.5 wheels I was hitting 85 mph in the carousel at Watkins Glen, a nice consistant threshold sweeper turn where you can really test the limits of a car if you are carefull. I got similar speeds from a set of 275/30-19 Yokohama AD08 tires and it turns out the tires have similar grip levels and tread width specs, although had slightly better response with the shorter sidewalls.
Next I tested some 265/35-18 Hankook RS3 tires on 18x9.5 wheels and hit 87-88 mph before drifting wide at the limits. This year with the 18x10.5 wheels using 285/35-18 Hankook RS3 tires that I "barely" fit into the wheel wells I was able to hit 90 mph consistantly in that same turn.
The lighter and stronger wheels are your best bet for sure, curently my tires are 30 lbs and the Volk SE37k 18x10.5 +15 wheels are around 18-19 lbs. I think my old Kosei 19x9.5 wheels were closer to 22-23 lbs but the 275/30-19 tires were only 28 lbs. Comparing the two sizes the 19" combo had better transient response with the shorter sidewalls but the 18" setup was still quite good once the starter rubber was worn away and had more grip mid corner due to a wider/stickier combo. I think that 18" wheels and tires are likely the best bet unless you want the looks of a 19" wheel and increased response with the penalty of slightly more weight. Going with 265 wide rubber on 9.5" wheels is probably fine for most people running under 500 crank HP, but once you start exceeding that range I feel that a wider wheel and tire combo makes sense.
why not run RPF1s 18x9.5 +15
They should fit nicely with 265/35 tires and are about ~18lbs a piece.
You can always offset a larger wheel/tire combo with lighter brake rotors
goofygrin
88
Jul 24, 2022 08:22 PM
Vivid Racing
EvoX 'For Sale' Wheels / Tires
Jun 19, 2013 11:02 AM
Chang_Wufei_05
Nov 30, 2010 05:14 PM
dyezak
60
Sep 14, 2010 08:30 AM
cyniclaus
13
Feb 26, 2009 07:25 PM
