Help - rusted frozen rear toe bolt
I love Cleveland and salt and cold and rust! My rear toe eccentric bolt does not turn... tried PB and lots of torque; no go. My next step is heat but I'm afraid to screw something up or break it. Anyone ever tackle this problem?
Note: I'm not asking what you should do or what you personally would do. I'm curious as to whether shops cook a bolt out of a bonded-rubber bushing and then give the customer back his or her car with the bushing no longer bonded to the inner and outer sleeves.
Do you check to see if you trashed the bushing afterwards or do you just carry on regardless, assuming that you manage to get the bolt out?
P.S. I know your post was from a year ago, but I figured I would take the time to respond to your inept accusations which imply that I am some careless, negligent individual who is damaging customer's vehicles.
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
They are not one size fits all unfortunately. Different vehicles require different sized and strength bolts. On the other hand, a lot of bolts will fit many different vehicle applications and work properly, but they must have proper fitment in order to allow the right range of adjustment and be able to properly tighten down and maintain the adjustment.
