Swift Spec R + Alignment ?
If you install swift sepc r springs on the evo x is there enough adjust in the factory suspension to get the alignment back to factory suggestions? I want to put these on but not looking to tear up tires.
As stated before, you would get negative camber. But with slight camber, you would still get camber wear on your tires. I'd get proper alignment after a week or so of installing the springs.
rebdull
Dec 8, 2011 02:35 PM
