Camber Kit help
Camber Kit help
Hi, I need some education on camber kit..
my 08 GSR is lowered on Tein springs. running on stock rims. I plan on getting new rims and coil over in the future, but for now, i'll be running this for a few years..
today when i went to get my alignment done, i saw that the rear camber bolt is broken and it's starting to bend the frame.
1) What is a good camber kit?
2) The shop says that only rear camber kit is needed. The front of our car is designed in a way that the bolt won't break. True?
The camber bolts up front have a "bump" in the bolt that allows for adjustment and cannot be broken. I don't have a picture of them but maybe someone else does.
The rear can add adjustment with aftermarket control arms by Agency Power, Megan Racing, and Whiteline which I can help you with.
If you want to keep stock camber like adjustment as you don't need something aggressive, head to the dealer and get another stock bolt. I cannot locate my EvoX manual right now for the part number as it is on another PC. I can get it in the morning.
I thought about buying another bolt. But it'll be a matter of time before it grinds down again and start damaging the frame. I'll just upgrade to aftermarket adjustable ones.
Junkyardspecial
Apr 24, 2016 12:52 PM
mitsuevodriver
19
Jan 17, 2016 08:37 AM
Evo Sportback
For Sale - Wheels / Tires / Suspension / Brakes
Jul 31, 2014 10:41 AM
