What size spacers do I need
Hey I'm trying to make my car look more stanced. I have xxr 527 in 18x8.75 +20 with a 225 tre on it. I'm in coilovers and my tire is just tucking. What size spacer do I need to get it perfectly flush I have 2.6 degrees of negative camber also. I would like it to be as close to flush as possible. Minimal rubbing
It doesn't even make sense. Stock wheels/tires with a 20mm spacer would be better than this.
You said that the stretch isn't that bad, but I don't think that's the point. You could probably do a 10-15mm spacer, but you need new tires. At a minimum, 245s.
Are these wheels from an VIII or IX? That would make more sense.
listen i got the rims 1 because they were cheap and i got the tires with the rims as a package. but whatever.
and about the poser comment, what exactly am i posing about? cause i want my car to look a little bit better? sorry if your a function guy. (and if your gunna call someone a poser... well you try and make it out like your a diehard track guy, invest in some coilovers not springs)
Sorry for being an ***... But I still think the wheel/tire/alignment setup you wanna run is lame... And so are your D2 coilovers...
Its going to be hard on that wheel bc its not wide enough and impossible on those tires. Im trying to just be honest not rude. I'm running your same wheels but 18x9.75 with 275 35 tires and a 5/16 spacer and I will be switching to 285 and taking the spacer off.
http://www.flickr.com/photos/54002004@N05/6342255559/http://www.flickr.com/photos/54002004@N05/6342255559/ by http://www.flickr.com/people/54002004@N05/, on Flickr
http://www.flickr.com/photos/54002004@N05/6343006210/http://www.flickr.com/photos/54002004@N05/6343006210/ by http://www.flickr.com/people/54002004@N05/, on Flickr
http://www.flickr.com/photos/54002004@N05/6343006682/http://www.flickr.com/photos/54002004@N05/6343006682/ by http://www.flickr.com/people/54002004@N05/, on Flickr
http://www.flickr.com/photos/54002004@N05/6343007152/http://www.flickr.com/photos/54002004@N05/6343007152/ by http://www.flickr.com/people/54002004@N05/, on Flickr
