cusco brace members
cusco brace members
Just doing some research on maperformance for my road racing setup and they have 7 cusco brace members for sale. My question is which ones should i go with? are they necessary? if anyone with them installed can give me some input thanks.
Very interested in these also since im looking at getting a full Cusco setup (Coilovers, swaybars, towers braces, and possibly frame braces.) But from what ive seen on some cars search Internet. The very front and rear seam to be the ones that most go with.
In general, a front-heavy car needs the most help keeping the lower front control arms apart (at least when the front suspension is optimized, so you have a lot of front grip). The two tubular OE braces (under the plastic shield) and the OE gussets do not look like enough, although I can't find any evidence on the web. But, again, in general, that's where you need the most help, so the front-most brace would probably be the most useful. Our chassis is quite strong, so unless you're set up with a huge amount of rear roll stiffness, I can't see the other braces doing much besides adding weight.
RcEvo09MR
May 12, 2015 09:10 PM
Racer RS X
Apr 19, 2005 05:21 AM
