Are our rotors this cheap?
http://www.discountbrakes.com/shop/?...ke,universal:0)
They are the centric blank rotors with the black centers. Is there anything wrong with these for daily driving?
If you redo the Search on the website you see them. I copied and pasted the info from the site below. Am I missing something here??
Sale Price:$36.98
CENTRIC FRONT BRAKE DISC - CENTRIC PREMIUM - OE COMPARABLE
2008 MITSUBISHI LANCER EVOLUTION GSR 4 CYL 2.0L -- CENTRIC PREMIUM BRAKE DISC, VENTED, SOLD INDIVIDUALLY
Get the most out of your stock braking system with Centric Premium OE replacement brake discs. These rotors are manufactured using OE specifications and processes under strict QS and ISO quality standards to give you an ever reliable braking performance. Furthermore, they are given machined finishes for smoother and cleaner appearance.
Specifications:
5 x 114.3 mm bolt pattern
276 mm disc diameter
13 mm bolt size
26 mm thickness
24 mm minimum thickness
Features:
Manufactured to meet QS and ISO quality system standards
Utilizes an electrocoating finish that provides long lasting corrosion protection
Designed to withstand 400 hours of salt water exposure without rusting
Double disc grinding ensures parallelism, eliminates run out, and provides near perfect disc thickness
The double disc grinding also leaves a non-directional finish on the friction surface area for more effective pad-disc break in while providing quieter and smoother stops
Center-split core casting offers proper heat transfer and thermal efficiency for superior braking and safety
100 percent fully machined hat delivers better disc balance
Mill-corrected to a tolerance of less than 2 oz. per inch
Fit Note: With Rear Drum Brake
Series:*Centric Premium
Quantity Sold:*Sold individually
Warranty:*90-day or 3,000-mile Centric limited warranty
Design:*OE comparable
Part Number: CE120.63068
Availability: In Stock
This Product Fits the Following Vehicles:
2008 Mitsubishi Lancer Evolution GSR 4 Cyl 2.0L
Sale Price:$36.98
Specifications:
13 mm bolt size
26 mm thickness
Features:
Last edited by infamus_jamakan; Apr 3, 2012 at 08:19 PM. Reason: Link doesn't show rotors I'm referring to
cquencebrakes
Vendor Classifieds
20
Dec 28, 2015 06:47 PM
SSickLS1
May 10, 2013 10:31 AM
Insanity Evo
Sep 30, 2011 05:59 AM
sdoow
Evo 'For Sale' Suspension / Brakes / Handling
Jan 21, 2007 09:22 AM
