How important are backing plates/grease for brake pads?
I did some research and everyone is hyping up the grease. I've always had Hawks, and they came with grease. I recently switched to Ferodo DS2500's, along with Girodisc's anti-noise shims in the front. I did not reuse the backing plates for the rear, it looked really worn out. No grease on all 4 corners.
My question is, should I order backing plates for the rear? And should I grease up all the pads? The car is going to be used as a daily driver, with occasional canyon runs and track events.
I just did my Ferodo 2500's. Was a little upset they didn't include grease. I used some grease on all of them and re-used the backings and they all work great with no squeaking so far at all.
I would suggest getting the new backplates honestly. I am sure you can get by without them but I would risk it. They are prolly cheap anyway.
Ok so they aren't cheap, lol. They show up as like 70-80 bucks. Still i would get them.
Reuse the stock shims. It will make a huge difference in reducing noise. If you're tracking, get the titanium plates; that will make a huge difference in brake life.
As for grease, I like the Permatex Ceramic grease (the purple stuff). Doesn't burn away even at track brake temperatures.
marcouxa1
51
Jan 10, 2016 06:47 PM
ihatemyusername
Jun 25, 2014 03:50 PM
weneversleep
Apr 15, 2010 08:46 AM
