Spacers and alignment
Just a quick question, installed gtworx springs a couple of weeks ago and taking my car in this Friday for the alignment. Do spacers make a difference in the alignment? I'm thinking about getting 15 or 20mm spacers for the stock GSR wheels but I may not have them until sometime after the alignment. Would I have to get it realigned?
Thank you
Thank you
Thank you
Thank you
I'm not positive on if it will affect your alignment or not, but if I had to guess I would say it wouldn't.
15-20mm is a lot.. You may have to get some of the longer ARP studs.
Alignment shouldn't change by increasing track width through spacers.. 2 degrees on toe is still going to be 2 degrees of toe and -2 degrees of camber is still going to be -2 degrees of camber.
Thank you. That is kind of what I thought but I wanted to make sure. I am still going back and forth on the spacers but I need to get it aligned for sure this friday. It's a busy place and had to make an appointment 2 weeks out to get the alignment and I don't want to drive around too long after it has been lowered and had the roll center kit installed without an alignment.
Thanks. I am leaning towards the 15mm. Wish I could see them in real life. I just don't want the wheels sticking too far out. I don't really like that look.
I'm assuming my set-up will be okay, cause thread engagement is a few millimeters longer than the nominal stud diameter. I also don't track with this set-up. It's strictly for daily driving.
+1
If you are using the stock wheels, you will need hubcentric rings.
If you are using aftermarket wheels that call for conical lug nuts, you will not need hubcentric rings.
just in case anybody has the same question, my alignment shop said the spacers won't make a difference in the alignment at all. Thanks everybody for your responses.
TxFAkuma
Apr 15, 2016 04:12 PM
nala
Jun 11, 2009 06:22 AM
shinobee1
May 28, 2008 08:48 PM
crusin_lancer
11
Jan 11, 2005 10:21 PM
