Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Valve Stems & OEM TPMS
Old May 22, 2012 | 05:24 PM
R Lar's Avatar
Was curious to know if aftermarket stems work with OEM TPMS? One of my valve stems has taken some damage and now the cap will not go all the way in. I wanted to replace it out with a Ray's/Volk valve stem.
Old May 22, 2012 | 07:30 PM
Iowa999's Avatar
Yes, you can get VDO senders that work and cost a lot less than getting them from Mitsu. Tire Rack, for example, sells them.
Old May 22, 2012 | 08:53 PM
R Lar's Avatar
Sorry in advanced i'm not too familiar with TPMS, but these VDO senders you talk about... It's not a complete replacement, is it?
I would just go to tire rack and pick up these senders and attach the new valve stems on to the old TPMS?
Old May 22, 2012 | 09:03 PM
Iowa999's Avatar
My turn to apologize. I didn't read your post carefully enough.
You cannot swap in alternative stems. But you might be able to fix the problem by replacing the core of the valve-stem. Worth a shot, since cores are cheap and the tire doesn't have to be unmounted.
bzager1
For Sale - Wheels / Tires
May 5, 2014 06:46 PM
wicked white14
Mar 28, 2013 11:40 AM
Magik
Oct 28, 2011 04:57 PM
brads09lancerGT
10
May 27, 2011 02:21 PM
turbo125
Feb 7, 2011 09:42 PM
