Installing KW V3 coilovers - FAILING
So I thought I could install these coilovers myself. Wrong. I was surprised by all of the different potential issues that using the stock hardware could present. Anyways, I've managed to install the fronts (although I doubt I've torqued the top nuts enough because the whole assembly turns), and even the rears.
However, the rears are clunkling like crazy! Almost to the point where I wonder if my suspension will fall out. So I've researched all day and I still cant quite find a straight answer. I think I am missing some stock components in the rear? I have the top nuts torqued to the oem washer on the rubber piece that sits above the OEM top hat. Under the oem top hat I used the KW supplied plate (looks like a washer) and the purple perch on the upper spring that mates up with the bottom of the top hat. I'm wondering if there should be an oem rubber bushing between the top mount and the KW plate that goes under the top mount? I'm guessing it's the plate hitting the top mount that is making the clunking noise? I question if that little plate can truly be that loud. Anyways, I never found the oem rubber bushing with my oem suspension, so I'm doubtful. Thanks all.
B
B
It clunks over bumps. I have the two bolts torqued down to the oem washer that sits on a rubber bushing. This is torqued down to the oem top hat. Beneath the oem top hat i have the kw supplied washer (i installed it without it the first time, to find the rod protuding through entirely...not cool). Everything else is the kw spring components. I think there is supposed to be a rubber bushing between the top hat and the kw washer? It wasnt with my oem suspension, so i'm not 100% sure. I just dont know what else it could be? Doesnt sound good and i find it crazy that the metal washer hitting the bottom of the top hat is making this amount of noise.
OneCrzyEvo21
May 24, 2016 12:29 AM
cmross13
Apr 22, 2014 09:36 PM
Shadowpriest
20
Feb 16, 2013 11:33 PM
evox_4x4
12
Mar 27, 2012 06:45 AM
belizelittle39439
41
Jan 14, 2008 09:29 AM
