What do you think of these D Force rims?
Great looking rims, can be painted or powdercoated any color. Mine are gunmetal
My 18x10's are 18.8 lbs ea and I beleive they retail for $300 per rim....
I also ran one of the first sets of these in the states back in 2006 on my Dakar M3/4.
I have 4 sets of rims now:
Einke 18x10.5-15 offset with 315/30/18 Hoosier A6's for Solo 2's in my ASP EVO MR
D Force 18x10's with 295/30/18 Kumho Street & rain comp setup
D Force 18x10's with 285/30/18 BFG R1's for Solo1 & track days instructing
Stock BBS OEM 18x8.5" with 255/35/18 Hankook RSA's Not sure what I'm doing with these now
Wow. According to the old rule - "light, strong, cheap ... pick two" - these things should bend from having their picture taken, because $300 for a 18# 18x10 is rather good.
(Full disclosure: I've never even heard of these before....)
edit: no-one tell Ken that I posted in this thread, OK?
D Force Rims have been around for 6+ years now....
http://www.dforcewheels.com/
Great wheels, here is my STi with them installed.
http://www.vorshlag.com/product_info...roducts_id=506
If your looking to buy some, I recommend hitting up Vorshlag and asking or Terry. Tell him Adam from MAP sent you. (No longer from MAP)
THe ride height is lower than stock but high enough for my 900F/1000R springs to keep the tires from making contact with the fenders under full load.
The fenders have been massaged and repainted to pull them out as far as possible. Our cars weigh much more than the previous generarion EVO's and STI's but also have some advantages as well.
The 315's on my EVO are unbeleivable. I have 20+ years Solo 2 experience and was one of the first BMEW E36 drivers who ran a 285/30/18 setup in BSP years ago...
check this out:
http://www.onehotlap.com/
Scroll down to Clips 2 and 3...The M3 driver is a friend of mine and he took the Nat TOur BSP win at Devens a couple weeks ago...I'm the ASP white EVO that cranked out FTD
Aggressive fender pull/roll and repaint
Take off wheel well liners, bend or cut off all fastners, plastic and metal
Cut rocker panel and bend support brackets to size (minor 45 degree trim needed)
MAX SEAT TIME
Would you have to run the 15mm spacer on the Enkeis if you were on a 285 r-comp? And do you feel the 315 really give you that much more grip over the 285 in solo2?
Thanks
Thanks
The wheel well mod is done for the 315's to clear at full lock. Just a small bit of the lower rocker panel is ground down for the tire to clear. Its legal....
