Widest Tire Size for Stock BBS Wheels?
Considering tire options when stock Advans ware out. What is the widest tire size that can be fitted on stock 18" BBS wheels? A friend suggested buying wider tires when replacing stock to get a flusher look. Is it possible and would I have clearance issues? I actually like the stock wheels just wish I had wider beefier tires.
If you go to SP, I would get smaller brakes from Thompson Fabrication and drop back to 16" or 17" wheels. If you plan to get R-S3s, I would just get a new set of 245s and some spacers and run in STU. If you stay in Stock, then someone shoved something like 285s A6s on OE wheels with 5mm spacers and did quite well.
Tires..
Atrophical
18
Nov 12, 2014 03:25 PM
MrAWD
17
Mar 21, 2014 07:01 AM
Beluga
Jun 2, 2010 10:39 PM
