Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Gtworx springs and neg camber
Old Jan 10, 2013 | 07:30 AM
1012Xmr's Avatar
Hey guys I installed my gtworx springs and must say I love the drop and ride its perfect but I let them settle a and got my alignment yesterday and the front drivers side camber is neg 2.1. All the other wheels are dead on to factory. My shop is telling me I'm going to need front camber plates. Just seeing if this is necessary as I thought this wasn't needed w these springs . Also you could visually see the top of the wheel leaned in a bit but all other wheels look fine. Thanks for any help
Old Jan 10, 2013 | 08:02 AM
momostallion's Avatar
you may have gotten the eccentric bolt flipped the other way during reassembly.
the eccentric bolt is the top bolt on the strut mount that has a dot of red paint on it. stock, it faces toward the strut. yours might be facing away towards the wheel, which will make the camber about 1 degree more negative.
Old Jan 10, 2013 | 08:05 AM
see this how to for pictures of the bolt:
http://www.evoxforums.com/forums/showthread.php?t=48705
Old Jan 10, 2013 | 08:54 AM
1012Xmr's Avatar
Cool thanks I appreciate it
Old Jan 10, 2013 | 12:08 PM
Iowa999's Avatar
And just to make sure: if that's the problem, you must remove the bolt completely, rotate it 180*, and then put it back in. These are not rotate-without-removing camber bolts. These are remove-and-flip bolts.
And then you get to pay for another alignment, although I'd argue that the shop owes you one for free for not knowing how to change your camber.
Old Jan 10, 2013 | 12:35 PM
GTWORX.com's Avatar
This. It doesn't seem like they tried very hard and/or they wanted to sell you some camber plates.
Please don't be afraid to call us when something like this happens!
- Andrew
Old Jan 10, 2013 | 01:10 PM
1012Xmr's Avatar
thanks im going to check it later when i get home !
Old Jan 10, 2013 | 01:13 PM
1012Xmr's Avatar
- Andrew
thanks andrew, ill call if i cant figure it out. they didnt try and sell me anything which i guess is good the mechanic told me to contact the company and come back for an adjustment if anything special was needed. its possible that i put the bolt back wrong im grateful for all the help thanks again everyone
Old Jan 11, 2013 | 09:10 AM
1012Xmr's Avatar
heres a pic of the bolt its the wrong way going to tackle it this weekend thanks again for the help
mrfred
15
Mar 22, 2016 05:27 PM
TouringBubble
62
Aug 7, 2012 10:57 PM
realjohn996
Aug 16, 2011 08:58 AM
GTWORX.com
EvoX 'For Sale' Suspension / Brakes / Handling
26
Mar 19, 2010 12:14 PM
triguy
14
Dec 29, 2008 04:27 PM
Quick Reply: Gtworx springs and neg camber
