H & R Camber Bolts in the Top Slot, OEM Eccentric in the Bottom Slot???
The lower hole has no provisions for an eccentric bolt, so I don't see how to do that easily. (Out of curiosity, what rule-set would allow you to go crazy with the connection between the strut and the knuckle and not allow upper plates?) In any event, if you are allowed to go crazy where the strut meets the knuckle, I suppose you could do something with a skinnier lower bolt, as long as you did something to keep it from shifting.
falcontx
Jan 31, 2008 10:29 AM
GTLocke13
Dec 6, 2007 05:55 PM
