tmps sensor?
tmps sensor?
I recently bought RPF1 SBC 18x9.5 +15 I went to the tires shop to take out my stock tires. put it on my RPF1 suddenly the guy told me the tmps sensor wont fit on my RPF1 told me the hole is to small now Im having on low pressure tires on my dashboard does anyone having issue on this? roll shop make the hole bigger or buy after market tmps ?
THANK YOU
THANK YOU
You'll just want to buy new sensors that'll work with the car. Just FYI, it's TPMS :P Tire Pressure Monitoring System.
http://blog.tirerack.com/blog/select...-market-wheels
While those aftermarket sensors might fit on the car, you are going to have to take the car to the dealership after you install them to have your car's ecu learn them.
If you need sensors that won't need to go to the dealership shoot me a pm. Although I would love to sell you sensors, I think the OEM sensors will fit in the RPF's ( if they are the OEM sensors in your car ).
I find all of this confusing, but I might lack critical information.
I have had RPF1s and I'd swear that they have .453" (11.5 mm) holes, just like the OE wheels. Yes, the OE sensors have the valve-stem firmly connected to the sensor, which can cause grief, but not because of the size of the hole. Did you get some strange Enkeis with the smaller-sized (8 mm) hole, instead? Or am I just completely wrong about the size of the hole on the OE wheels?
THANK YOU
THANK YOU
ya man i manager a lube/ tire shop and the tpms sensor should fit the new wheels they probably just were doing something wrong. And if for some strange reason you have different size sensors it would be cheaper for you to have the hole bored out instead of buying sensors and reprogramming them. sensors range from $60-$200 each and we would charge $18 for each one to unmount, installed, remount, reballence, and program each one.
Odds are, the person relaying the problem to the OP was either unclear or misinformed. What makes it difficult to install OE TPMS sensors in some wheels is how the sensor, itself, is attached to the stem. If there isn't an open area on the inside of the barrel of the wheel in the right place relative to the hole, then the OE sensors are hard to install. Not impossible, as I know it has been done, but not easy for a tech used to just following the steps in a manual to do.
Besides being reprogrammable, the Sens.It sensors (i.e., those that EvoM member N.G.S. programs and sells to the community at pretty much cost) have the advantage of being much more flexible with regard to installation. As crazy as this will sound, rather than disabling TPMS, I have sensors in my rally wheels. It would have been close to impossible to get OE sensors in 15" Braids. But, after not-so-subtly implying that I was a complete and total idiot for putting sensors in rally wheels, the tech who was mounting my gravel tires put Sens.It sendors in my wheels in less than 5 minutes.
dk3Jdefje1X
Jan 22, 2017 12:42 PM
dk3Jdefje1X
Jan 3, 2017 10:20 AM
WTB[MidWest]: Kelford 214 c's
The_X_Effect
Aug 17, 2016 01:04 PM
