Varrstoen ES1 Wheels?
I wanted to try and get a set of the Varrstoen ES1 wheels, but I'm not sure they'll fit.
Has anyone had experiences with these wheels? I'm running a 255/40/18 tire, my rear fenders are rolled, and i'm on a GTWorx springs.
Is there any fitment in this wheel that would fit without spacers?
THanks!
THanks!
They offer 18x9.5 +12, +22
18x10.5 +15, +25
Would any of those work? I'd like to stick with 18x9.5 due to my tires and to keep the installation as easy as possible.
18x10.5 +15, +25
I'm currently running 18x9.5 +20 rims and stock 245 tires with 1 finger gap all around. My fenders are not rolled and I have no rubbing issues. Since the Varrstoen rims are 2 mm further in, your fenders are rolled and you’re not dropped as much I can't see why you'd have any issues even with the slightly larger tires
Hey, peeps. There's really only one reason to have this thread: does the design of this specific wheel cause contact with the brakes. We already have myriad threads (plus stickies) on the question of what width and offset to use. If you have experience with Varrstoens, post away. If not, then, to be blunt, go away.
Yeah Ive been told that. I'm wondering if I should run the 18x9.5 +12 in the front and the +22 in the rear to avoid rubbing in the rear. Is it odd to run 2 different offsets in the front and rear? I thought normally people run more aggressive offset in the rear, but i'm wondering of the exact opposite.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
But then there's the issue of being able to rotate the tires. And there's selling the wheels when you decide that Varsstoens aren't pretty enough after all, etc. This makes me suggest the following:
Get something close to a +38 offset (for all four) and run 25mm spacers in the front and 15mm spacers in the rear. Tires can be rotated. Wheels are easier to sell. Type-2 spacers are perfectly safe.
Would it make sense to get the +22 all around and only run a 10mm spacer in the front only?
These tires could still be rotated, and everything would be fine?
People run lower offsets in the rear because they grew up drooling over 'Vettes and F-bodies (i.e., RWDs) and haven't digested the fact that they drive a front-heavy, FWD-style AWD car, instead. If anything, we should run wider tires and/or lower offsets in the front, to get the cars to turn and transfer less weight at that end. In other words, there is absolutely nothing wrong with running a lower front offset. In fact, front wheel-bearings are easier to fix, so it's the better of the two options.
