Prematurely worn Rotors on stock brakes
I just took my X in to the dealership for it's 30k maintenance and when they checked the brakes for wear they told me that the pads were due for replacement soon and the rotors were too thin to be machined smooth. Now I wasn't surprised about the pads, but the rotors shouldn't be that worn, right? This is a completely stock car with only 30k miles on it that's never been raced and is still on it's 1st set of brake pads. If the rotors need to be replaced every time the pads need to be swapped than something seems wrong to me...anyone else had this issue? Or is the dealer full of it?
Thanks,
Nick
Thanks,
Nick
I agree that you should have gotten more miles from the rotors, especially if you're on your first set of pads. Can you buy or borrow come calipers to measure your rotors to verify the problem?
In any event, don't get OE replacements from a dealer. We have plenty of vendors here that will sell you "blanks" or better for much, much less than Mitsu will ask for.
Your pads are probably about due, but your rotors should be fine. Slap in a new set of pads and call it good; with 30k miles on your stock pads that tells me you haven't been abusing them too much so the rotors should be perfectly fine for another set of pads. Hell, my rear rotors are on there 3rd set of pads at 63k miles with plenty of thickness still left. My front rotors are on their 3rd set of pads plus were turned once, and still have enough thickness to be within spec.
Thanks for the feedback. I have some calipers at work so I'll pull of a wheel and measure the rotors myself this weekend when I have free time. I suspect the dealership is full of it.
Our OE rotors are not thin.
Two-piece replace rotors would be exactly the same thickness, since they'd need to fit the calipers.
Less mass almost always means easier to warp.
Now, what was the question again?
One question, are the rotors worn unevenly? Sometimes the pads will wear the rotors unevenly or even put gouges in the rotor. Not saying that is the case here but it wasn't clear. If they are worn unevenly or possibly gouged a little, the dealership might be saying that they can't cut the rotors down far enough to remove the gouge and keep them within spec thickness. I have had that happen to previous vehicles.
Just a thought.
Just a thought.
FWIW I'm still on my stock rotors at around 97k miles. I replaced my OEM pads with Girodisc Magic pads at around 30k miles and I really need to get new pads on ASAP (mine are getting too close for comfort to the indicator clips). The stock rotors look just fine, but I'll measure them when I swap out the pads. You really have to be driving hard on the street with the stock pads to warp your rotors... REALLY hard...
OP here: I finally got around to checking the rotors and they were fine. I just did a simple pad swap and everything is working great...last time I ever go to that dealership!
Crankwalked2G
15
Apr 24, 2012 07:40 PM
sanjaya1
36
Sep 12, 2005 12:55 PM
EVOtook
46
Apr 10, 2004 04:24 PM
