Installed coilovers. Need to sched an alignment... Questions first.
So I installed my Eibach R1s yesterday and need to go in for an allignment (even though I was surprised how close I was without one).
Currently I am not running any wheels spacers, but running PlastiDiped stock wheels until I have the extra cash to buy the Gram Lights I want. Here's my question:
Can I get an alignment now and put wheel spacers on afterwards? Or will this throw something in the alignment process off again my initial alignment pointless? Thanks.
I have been told that it really wont change things that much but then I think to myself if the wheel is 20mm pushed out wont it cause the wear on the inner edge to be at a more severe "angle?"
On a side not I have 2 - Ichiba V2 20mm bolt on spacers for sale if you need some!
You'll be fine. Installing spacers don't change the alignment specs which is done by adjusting the camber bolts and adjusting the control arms. By pushing out the wheels more, you're increasing the leverage distance, and the camber may increase but very little...maybe .0002 degrees and won't make a difference in the tire wear.
These guys are way smarter on this stuff than I am. But ....
Your original ask implies that you are going to change from stock wheels to Gram Lights and add spacers.
Me, I buy aftermarket wheels that are bigger with more aggressive offsets than stock. Then I buy lower profile tires to match up with the Evo's systems. A lot of us do.
If the Grams are different in diameter, width and/or offset and/or you get new tires with a non OE profile, and add spacers, I would get back to the alignment shop immediately.
For example: my OE Enkeis have snows, my Work Emotions are 18 x 9.5 + 15 with extreme summer 265/35s and my 5zigen track day wheels are 18 x 10.5/10 +12 with 275/35s. The sets really need to be aligned differently.
Just sayin' ...
Just sayin' ...
Nothing worse than having a track ride-along on board with wide fronts grinding against fender liners and such under braking compression in the turns. I know from experience.
Snow tires aren't really effective with negative camber and squatting, lowered in the wheel wells. When you put on snows you really need to return to stock suspension settings.
If you shake your head maybe it should be over the lack of sufficient adjustable or self adjusting OE suspension components to accommodate these uses/conditions.
If you are referring to such cars as Audi All-Roads, which can alter ride-height on the fly, please note that none of these cars have self-adjusting toe or camber. In fact, I have no idea what "self adjusting OE suspension components" might be, but would love to learn more about them.
wheel choice, size, offset, spacers (same thing as changing offset), tire choice... don't effect alignment.
Just get it done at a decent place. Make them do it to your specs, if they say they can't do specific specs then leave. If they say all they do is get it within factory, then leave. Find a place that will get it exactly right, it's not that hard to do and is important it's done right.
Really!
And I was really only shaking my head because your post made it sound like every time you had a track day you got the car realigned. Having a dedicated set of track wheels I would think implies you track the car quite a bit. If you're getting an alignment every time you track the car....jeez my mind is blown at how much money you're spending. Lets say you track the car 4 times a year, which is nothing, and lets you have someone willing to do it for 60 an alignment. So that 120 an event no? At four times a year that's 480 bucks....which has me shaking my head.....am I being illogical?
Wapoosh
Jul 6, 2017 03:13 PM
phatty04oz
May 17, 2004 05:31 PM
