Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
10mm Ichibausa V1 Spacer question(s)
Old Feb 11, 2014 | 02:32 PM
Psybin's Avatar
Hello all,
I've been trying to find a definitive answer on this without much luck.
I've been doing some research and trying to plan a wheel/tire set up.
I've always been really drawn to the NT03-M but I know they require spacers to run on the Evo X.
So with the size of 18X9.5e27 -- It would bring the final offset of 17 with a 10mm spacer.
I know the ideal practical offset for the Evo X is 22, so 17 is pretty close.
My question is this.
Would it be unwise to just have the 10mm spacers on the front wheels? Would the approximate .4 of an inch be noticeable visually?
17mm offset in front, 27mm offset in rear.
Also, if I were to run the 10mm spacers with extended studs all around, would I be able to use the factory lugs to put on my spare, or would the acorns bottom out and not apply the proper amount of torque, and same question for the OEM wheels (which I assume would be fine).
oyezbr0
Mar 23, 2015 12:18 PM
ant_BLR
Apr 8, 2014 06:19 AM
Dosagex
Jan 27, 2010 07:08 AM
Boltz.
Feb 15, 2009 03:26 PM
diiirk@AwdMotorsports
Dec 23, 2007 08:52 PM
Quick Reply: 10mm Ichibausa V1 Spacer question(s)
