Slight wheel rub, alignment?
I had used the tire rim calculator to see if the rims and tires i bought would fit and it looks like it would but when i got it installed i'm having a problem when making a sharp left turn only. There's a very slight rub at the front of the wheel well with the tire. When i make a sharp right i don't have this issue. I wonder if it's something off with my alignment that's causing the problem.
I bought 18 x 9.5 e22 rims with 255 / 40 R18 tires. Everything else is stock including the ride height. I had a wheel alignment done about 3 months ago so i'm not sure if this it's really the issue. Anyone have any ideas? Thanks,
It would not surprise me if the fender liners aren't symmetrical, given how they're attached and how the contents of the front corners aren't the same. I, personally, would go at the liner(s) with a heat gun and be done with it. It is possible that it's the suspension, as I have seen mismatching caster on our cars, but that's difficult to impossible to fix, so I'd be back to the heat gun even if that were the case.
Trust me, it will eat it's way through the liner way before the tire looses any tread. I had all intentions to heat gun and push the liners out, but had an auto-cross event to go to before I had time to heat gun and push them out of the way. By the end of the 4 runs my fender liners had huge holes in them and no more tire wear lol.
cescpistol
Apr 4, 2014 03:30 PM
EvoJustin
16
Nov 24, 2013 10:57 PM
migs647
43
May 30, 2012 08:16 PM
EndlessRed
30
Nov 8, 2009 12:43 PM
