Fab'd Chassis Bracing
Mochi Performance and Design are currently fabbing chassis bracing for my car.
In progress, but here are some crappy iPhone pics:
Rear diff/rear subframe braces, aka "dog bones":
What they replaced:
Rear Strut Bar, which allows factory trunk plastics to still be used if you wanted to keep them:
Frame Rail braces:
More to come!
What they replaced:
Frame Rail braces:
More to come!
The bars weigh less than 5 lbs. But yeah, you're right, it's pointless weight (even if it's just 5 lbs) if there's no improvement. Unfortunately there's no way to measure chassis stiffness, so you kinda have to rely on feel and common sense. For example, look at the pieces that the diff braces replaced, one set is a thin flat piece of what almost feels like something a little thicker than sheet metal, and the other is a crimped tubular brace, both of which, when using common sense, flex a lot. Even the stiffest chassis from factory has it's weak points.
As for the other braces, we're adding them, testing the car in a corner, and these guys use my feedback (and driving style preference) to decide what changes to make.
On a side note, Nagua, when you said "gtfo my threads" I assumed that you'd do the same
Just wait til they're powdercoated red, that'll be atleast 12whp.
As to common sense, those red ones in the rear should not be pairs less than a few inches apart. They should be one piece with the third leg of the triangle added. When it comes to strength, triangles rock.
Thing is, while this thing is track driven, it's also somewhat of a daily driver, and the triangle that connects all three would be more than marginal, additional NVH. The stiffer/thicker bars that replace the factory braces do enough to prevent differential slop, while still avoiding unnecessary NVH.
It's kind of like polyurethane vs solid bushings... One helps reasonably, while the other is slightly better, but with additional cost.
I'm just kidding
Unfortunately not, grocery machine + track toy.
FS[West]: OEM Bumper Mesh [IX]
Treyzian
Sep 12, 2015 12:06 PM
Treyzian
For Sale - Wheels / Tires
Sep 10, 2015 06:57 PM
Treyzian
Sep 10, 2015 06:56 PM
FS[West]: OEM Oil Cooler Duct
Treyzian
Sep 10, 2015 06:51 PM
Treyzian
Aug 30, 2015 02:12 PM
