HELP xd9 18x10 +18 Evo X what size spacer?
I just purchased a set of xd9 absolutely love the wheels to death. I was wondering if anyone on here is running the same wheel. If so what spacer is needed for the front and rear or just the front is needed? I haven't got the wheels yet should be in next week.
there xD9 18x10 +18 offset
A few months ago i was told by work wheels. I would need 25mm in the front, but they didn't mention anything about the rear.
IMHO I would use the same size spacers on the front and rear
I ordered the wheels already suppose to be here Thursday. And I ordered a spacer just in case. Works told me a 25mm is needed so I guess I will find out. I have also heard the barrel is to small.
Isn't a 25mm spacer going to push a +18 10" rim way outside the fender? I have stock rims with a 25mm spacer and unmodded fenders all around. You would be 17mm closer to the fender just with 10" wheels (assuming similar tire sidewalls and a 265 or 275 tire) and another 20mm closer due to a more negative offset compared to the stock +38. I can't imagine that any amount of rolling or pulling is going to make up for that 37mm of added wheel outside of the fender. A 25mm spacer seems overly excessive for that setup on stock fenders.
Just wondering myself as I'm shopping for new rims and tires.
FilthyEvo
Jan 17, 2013 02:12 PM
