camber toe adjustment
Hey guys I have a 2011 evo x and recently lowered the car on d2 coilovers and now I am trying to adjust the rear camber because the wheels are too cambered inward .... I am wanting to set my camber back to 0... I recently purchased some Megan rear camber kits and when I went to install them I realized that I might possibly need to
buy some adjustable toe arms to properly align the wheels..??? Any help
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
You don't want your camber at zero. You want your toe at zero. You should be running a minimum -2 degrees of camber up front, and between .5 to 1 degree of camber less than the front in the rear.
hispanicpanicYou don't want your camber at zero. You want your toe at zero. You should be running a minimum -2 degrees of camber up front, and between .5 to 1 degree of camber less than the front in the rear.
Our tires roll too much to have any significant DD wear at -2. In my michelin pilot super sports, it took -3.6 in order to achieve a flat tire in a turn, just for reference. And that was on KW coils which will have much less body roll than a stock or spring'd evo.
As soon as I get home I'll post some pics of what I'm talking about... since I dropped the car about 2 inches the rear wheels are cambered way too much and I want to camber the wheels back out on top to sit flush with the body of the car..
Ok so this picture is the bottom of the rear end on the evo x... if u were to tighten the camber arm (red one) then it will throw the toe off and u can't adjust the toe...only a small amount...so after I installed the camber arm it made the car look like it had 4 wheel steering! So would that mean I need to buy adjustable toe arms to achieve a flush look?
And you've tuned this camber using what? IR thermometer? Or just corner feel? And what tires are you using? And the size? I ask because i just switched tires and have yet to dial in my camber on this 30 sidewall 295. Its requiring much less camber than my stock sized MPSS, which is def a good thing. 9 suspension geometry is nearly identical to x geometry, so there are more similarities than you think.
If you want reliable camber in the front, i suggest getting the toe arms as well. I have been running both the camber and toe arms and have great success getting my setup where I want it. It also takes me about 15min to dial in the rear. -2 degrees up front is a good start if you track the car. If it is DD, I really wouldn't go past 2, and 1.5 to stock if you are a big highway cruiser.
hispanicpanic, how much camber did you have dialed in before you started noticing significant inner tread wear on your PSS? I have -2.0 in the Front and noticed significant wear on the stock advans at < 10k miles. just curious what I should dial in on my new 275/35 PSS in the spring
255 RS-3s, tire pressure depends on the course. i've tried a bit more camber and noticed no improvement in handling, but felt a bit of a decrease in braking (may have been my imagination, as i have no way to prove it).
2.5/1.5 is brutal for daily driving, though LOL
